Java error after new install of 2022.0 ?
lifalin2016
Forum|alt.badge.img+30
Hi.
I've just finished a new install of FME Server 2022.0.0.2 on Windows Server 2019, and when I browse the management webinterface, I get the ugly Java exceptions below. Either one shows up when I refresh.
What is causing this ? Looks like a Tomcat issue, but how to fix that ?
error 500error 404I've made some small modifications post-install (not Tomcat), but all 4 services are up and running.
Cheers
Best answer by hkingsbury
I'm no tomcat or java expert, but the line 'no output folder' suggests the the account running the FME Server Services might not have sufficient read/write access to the install location and share resources location
hkingsbury
Forum|alt.badge.img+55
  • May 31, 2022
lifalin2016
  • June 1, 2022
Thanks @hkingsbury​
Actually it was just one of two mistakes, or rather forgotten steps.
I have done this exercise before, and did document the necessary steps at the time, but that documentation apparently has been lost (can't find it), so I'm retracing my steps.
The two steps I forgot was:
  1. Adding the AD account to the local Administrators group - which your suggestion pointed at
  2. Deleting all engine logs from the old account (C:\\ProgramData\\Safe Software\\FME Server\\resources\\logs\\engine)
When both steps was taken care of, the web interface started as expected.
So again, thanks for pointing me in the right direction 🙂
Cheers.
