How to specify a DNS server
  • November 23, 2022
  • 71 views
gazza
Does anyone know how to tell FME Server which DNS server to use?
Thanks.
Best answer by cory
Hi @Gary Nicholson​ this is determined by your Operating System.
If you log on to the Server (assuming you're running a Windows environment).
Start > Run
type cmd and click OK
type in ipconfig /all and press Enter
You will see the DNS Servers that are configured for that Server.
I would recommend contacting your IT Department if you need additional information.
cory
Forum|alt.badge.img+7
  • November 23, 2022
Start > Run
gazza
  • November 23, 2022
Thanks @cory​, that's what I suspected. The bad DNS server has been fixed now so we didn't have to make any changes.
