How to Connect & Access into $(Database Connections) SDE files on Flow
  • December 22, 2023
  • 112 views
bhk
Forum|alt.badge.img+3
What Parameter should we use to connect to .sde(s) file uploaded  to File & Connections-> Database Connections, on Flow?
$(FME_MF_DIR)part_etl_server.sde
Using above parameter we are able to connect the part_etl_server.sde which we attached into script publishing from Form but we need to connect into what we already have on server?
Thanks
Best answer by j.botterill
$(FME_MK_DIR) means the folder where the fme is stored, so when you publish to flow, click upload and select the SDE connection file to the same repository
j.botterill
Forum|alt.badge.img+38
  • December 23, 2023
