How to check FME server 2016 license expiry date ?
  • Jun 9, 2021 2:16 PM UTC
  • 101 views
How to check license expiry date ? any method by command prompt or from UI ?
How to check is floating license or normal ?
what is procedure to check for floating license expiry
Version 2016
Hi @avinashdalvi_​ ,
In FME Server 2016 a new licensing model was introduced and FME Server no longer uses the FlexLM Server but rather this is all configured through the Web UI (https://community.safe.com/s/article/moving-to-the-fme-server-2016-licensing-model).
To find out when your license expires in the FME Server Web UI go to Manage > Administration > Engine & Licensing:
2021-06-15_11-33-42
You also mention a floating license, this is used with the FME Desktop, not the Server product, were you also looking for information on how to check this expiry date?
