Get friendly text from Recurrence field on Schedules screen
  • Jul 12, 2022 2:00 AM UTC
  • 82 views
jorma
Looking to be able to use the FME Server API to get the text listed in the "Recurrence" column of the Schedules screen (see attached screenshot). Does anyone know if this is possible? Not seeing it when querying fmerest/v3/schedules. Thanks
  • Jul 12, 2022 7:58 AM UTC
It seems you'll have to generate this text yourself, based on the results from
GET fmerest/v3/schedules/<category>/<name>
See https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/schedules/get_get_3
Sample result:
  "owner": "admin",
  "request": {
    "publishedParameters": [
        "name": "SERVER_USERNAME",
        "value": "admin"
        "name": "BACKUP_DESTINATION",
        "value": "$(FME_SHAREDRESOURCE_BACKUP)ServerConfigPackage.fsconfig"
        "name": "BACKUP_APPEND_DATE",
        "value": "Yes"
        "name": "SERVER_PASSWORD",
        "value": "***"
    "workspacePath": "Utilities/backupConfiguration/backupConfiguration.fmw",
    "TMDirectives": {},
    "NMDirectives": {
      "directives": [],
      "successTopics": [],
      "failureTopics": []
  "workspace": "backupConfiguration.fmw",
  "description": "Backup server configuration to an FME Server Configuration package. By default, the configuration file is saved to the Backup shared resources and the date and time of the backup are appended to the filename. The backup contains the repositories, services, security, notifications, schedules and data shared resources.",
  "sharable": true,
  "repository": "Utilities",
  "skipUntilJobComplete": false,
  "userName": "admin",
  "enabled": false,
  "recurrence": "interval",
  "taskType": "transformation",
  "unit": "DAY",
  "name": "Backup_Configuration",
  "interval": 1,
  "category": "Utilities",
  "begin": "2012-01-01T02:00:00+01:00"
jorma
  • Jul 28, 2022 6:19 PM UTC
Thanks @david_r​ . That is what we are doing now, just wondering if there was another way. Sounds like that is the solution.
