FME server webserver results in 404
  • Feb 6, 2019 3:10 PM UTC
  • 117 views
When serving to fme server {hostname}/fmeserver it returns with an 404
Server is ubuntu 18.04
Type Status Report
Message /fmeserver
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
Forum|alt.badge.img+63
There's some FME Server troubleshooting guides that you can try. At first glance I would check whether the webserver is running and whether FME Server itself is running.
  • Feb 6, 2019 3:40 PM UTC
Thanks for the reply.
It steems like fme server is running since the process list is filled with java/fme processes.
Also the webserver is running because it is showing the 404 page.
From what i could find about this error it is an tomcat error which mostly occur when the path the application is not found or invalid.
Which config can i find this kind of settings?
  • Feb 6, 2019 3:41 PM UTC
