FME Server temp location
  • Jan 14, 2016 8:52 AM UTC
  • 209 views
fmelizard
Forum|alt.badge.img+22
I would like to know if it is possible to change the default Temporary location in FME Server.
The documentation does mention how to add a new shared resource location, but couldn't find any info on changing the default location (C:\\Windows\\Temp\\fmeengines)
Thanks in advance,
Itay
Best answer by david_r
Hi
You should define the environment variable FME_TEMP, as per this article.
You will have to restart FME Server for this to take effect.
David
  • Jan 14, 2016 9:16 AM UTC
Hi
David
fmelizard
  • Jan 14, 2016 9:30 AM UTC
Great didnt hink it will also work on Server, thx @david_r for the tip
