FME SERVER - FILE COPY WRITER - Invalid source dataset
  • Mar 25, 2022 2:50 PM UTC
  • 282 views
jasperwis
Forum|alt.badge.img+19
I have a workspace that runs successfully on desktop, but fails on FME Server.
I want to annotate/highlight validation errors in DWG files. So I created a second workspace, that's being triggered by a WorkspaceRunner/FMEServerJobSubmitter, to write these annotations using the correct original DWG as a template.
To collect this output in the output of the master workspace and make it available in the download service, I was thinking of using a File Copy Writer. This writer can then be included in the download service when publishing. As said this works perfectly on desktop. But when running on FME Server, I get the "File Copy Writer: Feature contains an invalid source dataset" error.
imageThough this file is definitely created on FME Server:
imageThis file exists and is not corrupted, so I don't have an idea why it's invalid.
I tried shortening the paths and filename, but no solution.
I also tried to add filecopy_dest_filename and filecopy_type, though these don't seem necessary when running on desktop, but no solution.
imageAny ideas?
Best answer by takashi
Hi @Jasper Wisbecq​ , how have you set the Wait for Job to Complete parameter in the FMEServerJobSubmitter?
  • Mar 26, 2022 4:13 AM UTC
jasperwis
  • Mar 26, 2022 5:45 AM UTC
Thank you @Takashi Iijima​ . I was searching too hard in one particular direction and overlooked this setting completely.
