FME server: Error submitting a job [only manually started]
  • February 6, 2020
  • 108 views
jayqueue
Hello,
So we upgraded the server to the latest version and now I can't run a workspace.
The error in the localhost.2020-02-06.log file.
06-Feb-2020 11:24:30.318 SEVERE [https-jsse-nio-443-exec-9] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [JobRunnerForm] in context with path [/fmeserver] threw exception
 javax.net.ssl.SSLHandshakeExceptionsun.security.validator.ValidatorExceptionPKIX path building failedsun.security.provider.certpath.SunCertPathBuilderExceptionunable to find valid certification path to requested target
When we try in FireFox we get "This is an unsafe certificate". Chrome en Edge mark the certificate as safe.
In the catalina.2020-02-06.log:
COM.safe.web.client.SelfSignedTrustManager.checkServerTrusted Server certificate chain received:
Certificate #1:
  Version: V3
  Subject: CN=internalservername, OU=X, O=Y, L=Z, C=BE
  Signature Algorithm: SHA256withRSA, OID = 1....
  Key:  Sun RSA public key, 2048 bits
We tried every method that we could find:
https://knowledge.safe.com/articles/19708/pkix-path-issues-when-configuring-ssl-for-fme-serv.html
https://knowledge.safe.com/articles/49624/fme-server-and-https-troubleshooting-guide.html
... but nothing works.
It only applies to manually running workspaces, scheduled job work just fine.
Could it be there an "error" in the backupfile that I restore?
Sincerely yours,
Jonathan
Best answer by jayqueue
Solved.
There were 2 cacerts
 Directory of C:\Program Files\FMEServer\Server\fme\jre\lib\security
08/12/2019  16:37           101.493 cacerts
 Directory of C:\Program Files\FMEServer\Utilities\jre\lib\security
06/02/2020  11:13           104.367 cacerts
I copied cacerts from \Utilities\jre\lib\security\ to \Server\fme\jre\lib\security - restarted - FIXED.
jayqueue
  • February 10, 2020
Solved.
  • April 18, 2023
Thanks for the above, saved us hours trying to troubleshoot the same issue which wasn't apparent to begin with.
swethabhupathi
Forum|alt.badge.img+3
Thanks for the solution. It worked well
