FME Server Engine Python Module - ModuleNotFoundError
  • Mar 30, 2022 8:53 PM UTC
  • 5 replies
  • 112 views
Our FME Server infrastructure is deployed in AWS on Docker, Core is running on dedicated EC2 with docker and engines are running on docker + EC2 which starts as users start the job.
I have a user who has a workflow that uses python script. We followed the documentation and asked the user to upload the module to Resource>Engine>Plugins>Python FOlder. After uploading the module user is still facing the error. I am suspecting this is related to the path where the module is and where the script is looking for the module. Most likely, I am not the first one to encounter this but I could not find any documentation or community post with examples that can help us solve this situation.
Any pointers?
Thank you in advance.
-Naman.
itsmatt
Forum|alt.badge.img+48
  • Mar 31, 2022 10:53 AM UTC
Hmm, I have a few custom modules in our FME Server (2020.0). I've put them directly into the
Resource>Engine>Plugins>Python Folder like you mentioned.
For example:
Resource>Engine>Plugins>Python>boto3
The folder should be part of the python path. If you want to debug you could have the user run a workspace which logs the python path variable. This should give you an idea on if it's included or not.
  • Mar 31, 2022 11:48 AM UTC
For example:
Can you please share what is the import line for the boto3 module workspace python script has? Is it absolute path to module or just module name?
itsmatt
  • Mar 31, 2022 11:52 AM UTC
just the module name
import boto3
  • Mar 31, 2022 11:54 AM UTC
What do you have configured as path on engine and core servers?
  • Mar 31, 2022 11:56 AM UTC
I mean do you have plug-in folder in the path environment variable?
