FME Server 2022 on Debian Linux: configure https with .pem files
  • Aug 10, 2022 7:53 AM UTC
  • 71 views
davtorgh
Forum|alt.badge.img+12
Hi everyone,
I've seen the https configuration is completely changed in FME Server 2022 compared to the one in FME Server 2021, due to the introduction of Nginx as a reverse proxy. The documentation, for Linux, says that private key and certificate files must be provided in .key and .crt format.
Now, I have private key and certificate files in .pem format and I'm asking if they can be used just as they are, because I have an Nginx installation (in another host with a completely different purpose than FME Server) that works directly with .pem files.
Thanks!
richardatsafe
Forum|alt.badge.img+11
Hi @davtorgh​ ,
While we haven't tested with a .pem file it should be possible as the nginx supports it. You will have to open file /etc/nginx/nameserver/ssl.conf and make sure the SSL certificate and key are pointed to the correct name and directory of your certificate though.
