fme-server 2021.0 and Esri compatibility
  • May 6, 2021 3:29 PM UTC
  • 5 replies
  • 149 views
Hi today we tryied update our fme-server from 2020 to 2021.
But we are not able to get it work with esri licensing within fme-server 2021 and arcgis pro 2.7
In fme-server 2020 everything work fine with arcgis pro 2.7
Thx for any suggest solution!
Best answer by antodang100
This article helped med!
https://community.safe.com/s/article/Using-ArcGIS-Pro-with-FME-Server
hkingsbury
Forum|alt.badge.img+73
  • May 6, 2021 8:03 PM UTC
Have you touched based with Safe Support? According to the compatibility matrix that combination should work
https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
I have role back to fme-server 2020 that used work before.
but still have this issuse:
Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility setting. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server. Refer to this this article http://fme.ly/qua for more details
hkingsbury
  • May 6, 2021 8:14 PM UTC
I'm assuming you still have ArcGIS Pro Installed? Might be worth removing it completely and re installing it to see if that resolves the issue
HI yes, we tried reinstall arcgis pro and the issue still there arcgis pro are 2.7.3 at the moment and fme-server is 2020.2.3.
we also have desktop in the same server, fme desktop work fine
  • May 6, 2021 8:44 PM UTC
