FME Server 2013 Web UI is slow
  • Mar 12, 2013 12:58 PM UTC
  • 81 views
geolassi
Forum|alt.badge.img+8
Hello all! FME Server 2013 Web UI seems quite slow, when trying to go to Repositories and to configure a published workspace. Running a workspace also seems to last forever, when running it from the Web UI, although the job itself takes only few seconds, when looking at the log file. Everything else works fast, like Jobs, Notifications, Schedules, Security, etc.
FME Server build is 13264 - win64. FME Server is installed with the express install on Wndows Server 2008 R2. Could this be problem in the environment? Has anyone experienced similar problems?
sigtill
Forum|alt.badge.img+25
  • Jun 27, 2013 9:15 AM UTC
Same issue here on the following setup, standard express install:
Microsoft Windows Server 2008 Server 4.0 64-bit Service Pack 2 (Build 6002)
FME 2013 SP2 (20130605 - Build 13499 - WIN32)
Might be a Windows Server 2008 issue?
Anyone from SAFE can comment on this?
  • Nov 27, 2013 6:51 PM UTC
I echo the slow UI of FME Server. I have to restart the server every morning to get going. Please keep us posted in here when someone gets to the bottom of this.
