Feature reader error
  • May 28, 2021 6:51 PM UTC
  • 179 views
Hello, I´m trying to run a workspace in FME Server...it works fine locally but in FME Server shows this error (see image attached). I have verified the FeatureReader Parameters and seems all is good....could you help me with this, please?feature_reader_errror
danilo_fme
Forum|alt.badge.img+58
  • May 29, 2021 1:38 AM UTC
Hi @velazquezmpablo​
Into your FME Server is allowed to extract your Reader into FeatureReader?
Thanks in Advance,
Danilo
Hi @velazquezmpablo​ ,
What is your FME Server Version/Build and what is your FME Desktop Version/Build?
I have seen this error before when you are publishing from a newer version of FME Desktop to an older FME Server. FME is not forwards compatible, that is, you should not use an older version of FME Server than your FME Desktop because there will be missing functionality so workspaces may not run successfully. Please try installing the same build of FME Desktop as your FME Server, and re-publish the workspace to see if that resolves the error.
