Error while starting the Service
  • Sep 24, 2022 9:53 PM UTC
  • 67 views
asadamjad
Participant
Forum|alt.badge.img+12
I am getting error while starting the services on local machine where I install the FME Server
Best answer by siennaatsafe
Hi @asadamjad​ ,
It looks like there is some issue with your database.
What kind of install is this? Is it an express install? Do you have the database or the systems share distributed?
Some things you can check are:
  1. Check that port 7082 is open and available on your machine. More instructions can be found here
  2. Check that your DB password matches what you set during the installation. The password for the FME Server Database is stored in the fmeDatabaseConfig.txt configuration file.
  3. Make sure the database service is running under the local system account and not a user account.
If these quick steps don't work for you please open a support case with us here.
siennaatsafe
  • Sep 26, 2022 4:06 PM UTC
Hi @asadamjad​ ,
