Error message "failed to register FME Engine" keeps on repeating under System events. However.... the engine is registered and works just fine. The error repeats every minute and completely drowns out other logs. How do I stop it?
  • February 1, 2021
  • 7 replies
  • 619 views
totobobiasos
Event Description: Error was recorded in fmeserver.log file.
Event Title: Error Logs
Message: Failed to register FME Engine.
This also keeps on repeating:
Message: FME Server license does not allow more than maximum of 1 FME Engine(s).
Best answer by redgeographics
If this is a standard Express installation of FME Server it may be trying to spin up a second engine that your license doesn't allow for. Check the number of engines you have specified in the Engines & Licensing section of the UI, if it's 2 set it back down to 1.
Forum|alt.badge.img+49
  • February 1, 2021
totobobiasos
Ah! That did the trick.
jnknnn
Forum|alt.badge.img+5
  • June 7, 2024
I encountered the same problem. I have system events like:
Message: FME Server license does not allow more than maximum of 4 FME Engine(s).
multiple times a day. I’m using system events in my automation and I have to filter engine messages out from “real” errors. I have deployed fme server in kubernetes but we don’t have any auto-scaling features enabled for fme-nodes. All engines and jobs seem to work correctly and license and engine deployment ui shows 4 engines as they should. What could be the reason for the messages?
baileyatsafe
Forum|alt.badge.img+11
Hi @jnknnn !
Can you try the following steps:
  1. Set the Engine Count down to 0
  2. Wait for all Engines to disappear from the Active Engines
  3. Bring the Engine Count back up to 4
If that doesn’t work, feel free to submit a case with our support team to troubleshoot further.
-Bailey
jnknnn
  • June 11, 2024
@Baileyat
 I assume setting the engine count from Engine Management > Engines > Hosts are feature only in the newer versions of fmeserver since I can’t find it (or not available in kubernetes version of fmeserver)? We are using fmeserver 2021 still. I could scale down the engine machines from kubernetes to zero and then back to 4 which would terminate current engines and create new engines from scratch. However, that would be bit of a hassle since it should be done in production environment.
nielsgerrits
Forum|alt.badge.img+54
Engine count can be found in server 2021 under ADMIN → Engine Management → Engines → Hosts.
jnknnn
  • June 12, 2024
Engine Management → Engines shows Total active engines: 4 as it should. I dont see Hosts -option
