Emailer not installing
  • Apr 27, 2023 9:10 AM UTC
  • 458 views
wvdmanden
Hi, i have a emailer transformer in my workbench.
Ik get an error:
812023-4-27 10:51:20 | Python Exception <ModuleNotFoundError>: No module named 'fmepy_emailer'822023-4-27 10:51:20 | PythonFactory failed to load python symbol `fmepy_emailer.Emailer'832023-4-27 10:51:20 | Factory proxy not initialized842023-4-27 10:51:20 | Emailer_CALLER (PythonFactory): PythonFactory failed to process feature852023-4-27 10:51:20 | An error has occurred. Check the logfile above for details
When i search fme support for a solution is see posts that i should remove some things in de packages etc. But in my packeges there are no files from emailer. I tried removing the root folder(system) bust it came back but still with no emailer packages.
Versions of fme workbench and server are the same 2022.1
Can i manualy put fmepy_emailer files in teh map, as so where can ik find the files from workbench.
merlinegeorge
wvdmanden
  • Apr 28, 2023 10:29 AM UTC
I found a problem. When i use an old emailer transformer en copy it into my new workspace it works. It goes under the upg4radable transformers, but if i use it like that it will work. Probem is the newer version of the emailer transformer.
danminneyatsaf
Forum|alt.badge.img+13
@wvdmanden​ if you go to Tools (in the FME Workbench Tool bar) > FME Options > FME Packages, do you see an Update Available for the Emailer package? If so I recommend upgrading the package and seeing if it resolves the issue. If not, you could perhaps remove the existing Emailer package and then Re-add the Emailer in your workspace and this will install the Emailer package as a clean install.
