Do I need a ArcGIS installation on the same server to be able to write to sde.
  • Jul 19, 2022 11:54 AM UTC
  • 97 views
ronnie.utter
Forum|alt.badge.img+11
I should know the answer and I should be able to answer it by my self. But the costumer need an answer asap and I think its quicker to get help from this fantastic community with all this amazing brains and experiences.
I know that If you have a FME desktop Esri Edition installed and want to write to a SDE och gdb you also need an ArcGIS installation installed for the license. Is it the same requirements as with FME server and are there in that case any way to change a setup file and point to the installed ArcGIS so that you dont need to install the softwares on the same machine?
Forum|alt.badge.img+63
ronnie.utter
  • Jul 19, 2022 2:03 PM UTC
thank you
