Connection problem S3
  • Aug 18, 2021 10:43 AM UTC
  • 6 replies
  • 153 views
peteralstorp
Forum|alt.badge.img+8
PANIC.
I have downloaded the latest Amazon S3 FME Package version 1.1.3.
My S3 Web Connection on desktop runs fine. But when I uploaded a script to FME Server I get the error message below and I cannot find a way to solve this.
Your help would be much appreciated!
Peter
 2021-08-18 12_53_58-Jobs - FME Server
nielsgerrits
Forum|alt.badge.img+67
I would try:
Manually download the previous version from https://hub.safe.com/publishers/safe/packages/s3connector
Remove newer package from desktop and server, install previous again.
peteralstorp
  • Aug 18, 2021 12:04 PM UTC
I would try:
Thank, @nielsgerrits​ !
Is there a smart way to remove packages in a structured way from FME Server? It seems that the package is split up into different folders...
nielsgerrits
I don't know to be honest, never tried, but I know you can download previous versions from the hub.
Personally, I would just try, it is not working now so you can't break anything. :)
peteralstorp
  • Aug 18, 2021 12:52 PM UTC
@nielsgerrits​  I tried but it didn't work. So I removed the package-items manually and tried re-uploading but nothing happens. And the panic is rapidly increasing...
nielsgerrits
Then you need to contact your reseller or safe software's helpdesk I'm afraid.
peteralstorp
  • Aug 18, 2021 1:16 PM UTC
What a strange problem. I finally managed to upload the package correctly. I don't know if it was due to the fact that I removed some items manually or if there was a mismatch between my Transformer and my FME Package. I must say the setup is a bit too complicated for me, with web connection, web service and fme package... Anyways, I'm a happy camper now. And thanks again for your input and interest, @nielsgerrits​
