Clipper problem invalid reader keyword
  • Apr 20, 2021 10:44 AM UTC
  • 86 views
Hello,
this is the log from FME server. The reader is a known source that works without any problems in other workspaces, that is why I find this part of the log strange:
" contains invalid reader keyword '{{*}}'. "
The workspace works locally but not on FME server (serverapp with geometry picker).
Anyone encountered this problem?
62Factory definition 'FACTORY_DEF {{*}} RasterClippingFactory FACTORY_NAME Clipper_Raster INPUT CLIPPER FEATURE_TYPE Clipper___ClippersForRaster___ INPUT CLIPPEE FEATURE_TYPE Clipper___RasterClippees___ MULTICLIP YES MERGE_CLIPPER_ATTRIBUTES NO ATTR_ACCUM_MODE HANDLE_CONFLICT ATTR_CONFLICT_RES CLIPPEE_IF_CONFLICT CLIPPER_PREFIX <Unused> PRESERVE_CLIPPEE_EXTENTS NO FLUSH_WHEN_GROUPS_CHANGE No OUTPUT_NO_CLIPPERS_AS_OUTSIDE OUTSIDE_NO_CLIPPERS_ATTR _fme_no_clipper OUTPUT INSIDE FEATURE_TYPE Clipper_INSIDE _clipped no OUTPUT CLIPPED_INSIDE FEATURE_TYPE Clipper_INSIDE _clipped yes OUTPUT EXTRA_CLIPPER FEATURE_TYPE Clipper__delete__ @Tcl2(FME_LogMessage fme_warn 917351 Clipper)' contains invalid reader keyword '{{*}}'. Opening and re-saving the workspace may fix this error. If the problem persists, please visit http://www.safe.com/support to contact support
Best answer by kailinatsafe
Hello @jakobther​ , thanks for posting! Do you know what version of Workbench and Server you are currently using? I've found a related issue with the clipper in 2020.0. This issue should be resolved in builds 20194+. It may be fixed by opening the workspace, and then resaving it workspace in the newer build. You can find our downloads page here. Hope this helps, Kailin.
kailinatsafe
Forum|alt.badge.img+24
  • Apr 20, 2021 9:16 PM UTC
  • Apr 21, 2021 6:16 AM UTC
thank you very much, it worked after upgrading my desktop to a newer build.
