Can I use IIS as the Web Application Server?
  • Mar 21, 2017 8:55 PM UTC
  • 183 views
fmelizard
Forum|alt.badge.img+22
Can I use IIS as the Web Application Server? I don't know much about Tomcat.
Best answer by fmelizard
No. FME Server's web applications are java based. A java web application server is required. IIS is not a java web application server.
IIS may be used in conjunction with a java web application server, for example:
https://knowledge.safe.com/articles/632/using-iis-and-arr-as-a-reverse-proxy.html
fmelizard
  • Mar 21, 2017 8:57 PM UTC
