Add How-To Enable HSTS within HTTPS Documentation - Already Implemented
sameer
Forum|alt.badge.img+16
Not sure if it might benefit others but I’ve recently had to enable HSTS to harden the HTTP redirect from Port 80 to 443.
Edited the web.xml file and located the HSTS Comments. (~Line 468)
Added the below filters
<!-- Enable HSTS   -->
<filter>
<filter-name>
httpHeaderSecurity
</filter-name>
<filter-class>
org.apache.catalina.filters.HttpHeaderSecurityFilter
</filter-class>
<init-param>
<param-name>
hstsEnabled
</param-name>
<param-value>
true
</param-value>
</init-param>
<init-param>
<param-name>
hstsMaxAgeSeconds
</param-name>
<param-value>
31536000
</param-value>
</init-param>
<init-param>
<param-name>
hstsIncludeSubDomains
</param-name>
<param-value>
true
</param-value>
</init-param>
<init-param>
<param-name>
hstsPreload
</param-name>
<param-value>
true
</param-value>
</init-param>
<init-param>
<param-name>
antiClickJackingOption
</param-name>
<param-value>
ALLOW-FROM
</param-value>
</init-param>
<init-param>
<param-name>
antiClickJackingUri
</param-name>
<param-value>
https://OUR_PRIMARY_DOMAIN.HERE
</param-value>
</init-param>
<async-supported>
true
</async-supported>
</filter>
<!-- Enable HSTS Filter  -->
<filter-mapping>
<filter-name>
httpHeaderSecurity
</filter-name>
<url-pattern>
</url-pattern>
<dispatcher>
REQUEST
</dispatcher>
</filter-mapping>
My PowerShell script to check if it’s enabled:
PS: Maximum redirection can obviously be amended. If maxage… is returned then HSTS is enabled. Alternative is to check the Header using your Internet Browser’s Developer Tools.
#Author: Sameer Abdool
#Create Date: 22/02/2024
#Purpose: Check if HSTS Policy is enabled
#Replace value of ServerName
$ServerName = "YourServerName"
#Build URL
$Domain = ".your.domain.com"
$URL = "https://$ServerName$Domain"
#Check URL is correct
Write-Host "$URL"
#Trust All Certificates - This avoids trust relationship for the SSL/TLS secure channel in PowerShell
add-type @"
   using System.Net;
   using System.Security.Cryptography.X509Certificates;
   public class TrustAllCertsPolicy : ICertificatePolicy {
      public bool CheckValidationResult(
      ServicePoint srvPoint, X509Certificate certificate,
      WebRequest request, int certificateProblem) {
      return true;
[System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
#Get the response headers by pulling out its Headers property
Invoke-WebRequest -Uri $URL -MaximumRedirection 10 | Select-Object -ExpandProperty Headers
steveatsafe
Forum|alt.badge.img+12
  • October 3, 2024
@sameer
Thanks for this post and for joining the “FME Flow Fundamentals for Admins” webinar this morning for sharing this question.
I see we do have an article on enabling HSTS header, https://support.safe.com/hc/en-us/articles/25407468300173-Enabling-HTTP-Response-Headers-to-Secure-the-FME-Server-Web-Application-Server
I also see an issue reported against FME Flow when this is configured so it is good that you have had success.
The request is to have HSTS Header enabled by default.  Feel free to create a support ticket so we can attach the ticket to the enhancement request.
steveatsafe
  • October 23, 2024
Hi again @sameer,
Thanks for connecting with us on this subject.
As we’ve recently shared in the support ticket that we opened, the biggest reason for not enabling HSTS Header by default is due to an issue that appears with the FME Flow Dashboards. The issue remains and we do not have a timeline on fixing.
So anyone that does enable the HSTS Header will experience a blank page for the Dashboards.  The issue is recorded as FMEFLOW-22805.
We also noted that the additional parameters/configurations shared don’t seem to apply one way or the other to a successful HSTS Header enabling. So you can follow our documentation if enabling HSTS Header is a must.   Just know, Dashboards will not work.
This is all we can share at this time.  Thanks again!
