XMLXQueryExtractor extract Attribute
  • Apr 4, 2023 10:59 AM UTC
  • 100 views
jkr_wrk
Forum|alt.badge.img+37
I have the following XML:
<?xml version="1.0" encoding="UTF-8"?>
<MyProblem>
<Maat Name="MyName1" Description="LetsDoIt">
<Status_Maat Value="Open"/>
</Maat>
<Maat Name="MyName2">
</Maat>
<Procon Description="FinalCheck"/>
<Precon Description="StopAndCheck"/>
<Maat Name="MyName3" Description="LetsDoNothing">
</Maat>
</MyProblem>
I can extract the Maat with XMLXQueryExtrator by the following expression:
/MyProblem/Maat
Notepad++ XMLTools says the path to the Description is
/MyProblem/Maat/@Description
but this gives an error. And no results.
What am I doing wrong?
Best answer by ebygomm
Try
/MyProblem/Maat/@Description/string()
Forum|alt.badge.img+54
  • Apr 4, 2023 12:49 PM UTC
Try
jkr_wrk
  • Apr 4, 2023 1:21 PM UTC
Thanks, that worked.
