Writing to PDF in Hebrew
dor1411993
Forum|alt.badge.img+5
Hello everyone!
I create an app for field reports, not something very complicated.
I want to produce the reports in PDF format.
I used this guide:
https://community.safe.com/s/article/creating-pdf-cartographic-output
My question is for writing in Hebrew.
For some reason, I can not write the text in Hebrew in PDF.
This is what it looks like in workbench, the caption I want to appear as a title:PS_1And this is the output in PDF:
PS_2I tried to manipulate the PDFStyler, including setting up the writing system: Hebrew
And nothing helped.
any suggestions?
for example, this is how it is supposed to look like:
PS_3
Thsnks!
Dor
Forum|alt.badge.img+50
I wonder if it might be a font issue. Sometimes the PDFStyler seems to revert to a substitute font, if that doesn't have a Hebrew character set it won't work (although I'd expect "blank rectangles" to show up).
Could you attach that PDF here so I can have a look in Adobe Illustrator?
dor1411993
  • August 4, 2021
This is the PDF ,Although I used the Arial font, which is a Hebrew font.
In the meantime, I found a detour, not the most convenient, but works.
I used MapnikRasterize to create a sort of caption image.PS_1
But I wonder why he does not let me write in Hebrew ..
It looks like the Hebrew characters never even made it in to the PDF. Not sure what to say to be honest, other than inspecting the output of the PDFStyler to see if they're there.
dor1411993
  • August 4, 2021
After the PDFStyler there are the Hebrew characters ..
only when it writ it down to PDF it's disappear..
PS_1
daraghatsafe
Hi @dor1411993​ thank you for your post, this is currently a known issue in FME. I am going to add a link to this post in the issue. Unfortunately, there is no timeline set on this issue at the moment. The tracking number for this issue is FMEENGINE-56522. Similar issue FMEENGINE-36955.
Thanks, Daragh
