Writing to Generic Writer with 4 output options: FGDB, SHP, KML, AUTOCAD Map 3D Object Data
  • October 27, 2021
  • 7 views
My reader contains two features: 1 line, 1 point.
My output writer is set as Generic and with User Parameters to choose the output options. But the attributes/fields I pick are captured only in SHP/FGDB/KML but not Autocad Map 3D Object Data.
Any clue how I can include the attributes I want in the autocad output?
danminneyatsaf
Forum|alt.badge.img+12
Hi @wlau​, would you be willing to provide some sample source data and the workspace? This way I'll be able to take a better look and troubleshoot the issue. If you're not comfortable sharing your files here on the Community, you could also upload the data to our Support FTP or submit a support case here.
