Writing merged attributes to excel
  • Mar 22, 2022 12:14 AM UTC
  • 118 views
smfks911
excelWriterIssueHi there, I have merged two tables by using FeatureMerger and kept some attributes by using AttributeKeeper. when I am writing this merged table to Excel by using Writer, I am asked to choose a feature type from two. If I select one, the writes takes all attribute from one type. In that instance, some attributes from the merged table are left out. Can anyone kindly tell me how to overcome this issue? A screenshot is attached here. Thanks in advance.
Forum|alt.badge.img+54
  • Mar 22, 2022 8:47 AM UTC
If you just wish to write the attributes you've kept in your AttributeKeeper, when you add the excel writer change the Sheet Definition to Automatic
