Writing CSV file with leading and trailing spaces in the field names
  • Sep 16, 2020 3:07 PM UTC
  • 266 views
pmcpherson
Forum|alt.badge.img+11
I'm trying to write a CSV file with leading and trailing spaces in the field/column names. I know this is unusual, but is required for a specific deliverable. The feature writer transformer does not appear to allow this. Any ideas on how best to accomplish this?
  • Sep 16, 2020 3:12 PM UTC
I was able to make it work by importing the feature type definition from an existing CSV with spaces in the column names.
pmcpherson
  • Sep 16, 2020 4:49 PM UTC
Thanks for the quick response. I'm not really sure how to implement that solution, but I'll try it.
Forum|alt.badge.img+54
  • Sep 16, 2020 5:13 PM UTC
You could also just choose not to write the field names in the writer, and send a record which contains the field names including spaces as the first record to write.
pmcpherson
  • Sep 16, 2020 6:04 PM UTC
Thanks to all for your help. Turns out I was making a simple mistake, which resulted in a problem that should not have been a problem. It is simple to add the white space in the writer itself by using the "Manual" radio button under the "User Attributes" tab. When I did that, I inadvertently forgot to update the "Value" field on the right-hand side to the pane to correspond with the correct source field, which at this point does not automatically match due to adding the white space manually.
