Writer Geodatabase ,change color of data before writing into it
  • Nov 20, 2022 8:05 PM UTC
  • 176 views
spiderman
Forum|alt.badge.img+7
I am using geodatabase writer and I am using test filter before the writer and my data are lines and points .
I would like to change the color of lines and points before writing it as geodata base .
my target :when open the geodatabase file later.it shows different colors for different lines depends on specific attribute .
so will be possible to change color of lines ?
dustin
Forum|alt.badge.img+36
  • Nov 21, 2022 1:37 PM UTC
This would be a function of the software used to display the data, rather than FME. If you are using ESRI, you would save the desired symbology as a map in a project (ArcPro), or an mxd (ArcMap).
spiderman
  • Nov 21, 2022 1:48 PM UTC
could I save the desired symbology from FME in different colors ? Then open it later in ArcGis pro .
i am using FME Desktop professional
dustin
  • Nov 21, 2022 1:53 PM UTC
You can use the File Geodb Open API writer. As I mentioned, the easiest way to save the symbology will be with a template, either MXD or map/project. The template is saved with the connection to the geodatabase and the desired symbology.
spiderman
  • Nov 21, 2022 4:02 PM UTC
Thanks for reply .
i am new here ,
my example : I have 4 different lines as data output , each line has new color depend on specific name in Attribut.
i understood that I have to save target symbology by Esri to use it as template in FME ?
But how could save the desired symbology as template from ArcGis pro ?
Do u have an example for me ? Or a link that I can show the idea ?
sorry for asking but I am new and I do not know how to do it correctly .
Thanks a lot for help
