Why is featurereader reading way more records than are in the input?
  • Aug 18, 2023 11:59 AM UTC
  • 8 replies
  • 157 views
rmcgregor
Starting out with feature reader, and I am definitely missing something. The input dataset has about 1,600 records. Why is the output at 366,458 (and counting) about 10% of the way through?
Thank you,
Best answer by geomancer
Visualization of the three different possibilities I mentioned.
geomancer
Forum|alt.badge.img+71
  • Aug 18, 2023 12:30 PM UTC
Yeah, this is a common mistake...
As the documentation mentions, a complete read is done for each feature that enters the Initiator port.
The Initiator exit port shows there are 218 initiating objects processed (so far), so every record in the input data set has been read 218 times (so far).
You should have only one feature enter the FeatureReader.
rmcgregor
  • Aug 18, 2023 12:33 PM UTC
Thank you. Can you select for a single record in the input? ie 'uniqueid = 1'?
geomancer
  • Aug 18, 2023 12:37 PM UTC
You can use a Sampler, sampling only the first feature that enters.
Or you can place the FeatureReader after a Creator.
Or maybe (depending on the input source) you can replace the Creator and the FeatureReader with a SQLCreator.
geomancer
  • Aug 18, 2023 12:48 PM UTC
rmcgregor
  • Aug 18, 2023 12:49 PM UTC
Thank you. I appreciate it. Yes, it was reading each record 1681 times. A where clause that selected a single records seemed to work.
rmcgregor
  • Aug 18, 2023 1:00 PM UTC
I've tried scenario one and the 'generic' output, which has the correct number of records, has no fields '<no schema>'
rmcgregor
  • Aug 18, 2023 1:11 PM UTC
Sampler and specifying the output port seems to do the trick. I really appreciate your help.
geomancer
  • Aug 21, 2023 8:13 AM UTC
Ah yes, I created a quick mockup for the visualization. You should indeed specify the output port.
I'm glad I could help you.
