Where can I download FME Desktop 2013 SP1 specifically?
  • Oct 19, 2017 2:12 PM UTC
  • 89 views
I have to maintain a large number of workbenches that run on FME Server 2013 SP1 (Build 13450). There are external dependencies and third party plugins that make upgrading to newer versions of FME Server not an easy task done in a swift.
But after updating one of the workspaces, I now get this error:
The clause 'REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE Value_ortofoto_jpg_fil Valuepath_windows' within 'FACTORY_DEF * ReferenceFactory FACTORY_NAME FeatureMerger INPUT REFERENCER FEATURE_TYPE StringConcatenator_2_OUTPUT_1 INPUT REFERENCER FEATURE_TYPE Sampler_SAMPLED INPUT REFERENCEE FEATURE_TYPE AttributeKeeper_OUTPUT REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE Value_ortofoto_jpg_fil Valuepath_windows MERGE_ATTRIBUTES Yes MANAGE_FME_TYPE Yes MODE COMPLETE PROCESS_DUPLICATE_REFERENCEES No OUTPUT COMPLETE FEATURE_TYPE FeatureMerger_MERGED' is incorrect. Only one value can follow REFERENCE_INFO
Basically, "The clause [...] is incorrect. Only one value can follow REFERENCE_INFO".
After googling "Only one value can follow REFERENCE_INFO" errors, it seems to stem from publishing workspaces from a desktop client that is of newer version than the server. And this is indeed the case for me, as my desktop installation is 2013 SP3, while our server is 2013 SP1.
I don't want to upgrade or change the server, in case that would break something else. My goal is to fix the error now, and upgrade the server properly later. I thought I'd first try to downgrade my desktop installation to FME Desktop 2013 SP1 and republish the workbench that fails. But I can only find download links for FME Desktop 2013 SP4: https://www.safe.com/fme2013
Where can I download FME Desktop 2013 SP1 win32 specifially?
Best answer by fmelizard
For older versions of FME, not available through the Previous Versions of FME page, please contact FME Technical Support. Thank you!
  • Oct 19, 2017 2:15 PM UTC
I suspect you'll have to contact Safe support for that one.
fmelizard
Forum|alt.badge.img+22
  • Oct 24, 2017 4:43 PM UTC
