When using Intersector in FME Server 2020.1 Build 20594 - linux-x64 the processes get freeze or sometimes the process restarts without given errors messages, same processes run in FME Workbench in Windows based computers with less resources.
  • Nov 11, 2021 6:04 PM UTC
  • 29 views
DanAtSafe
Forum|alt.badge.img+23
  • Nov 11, 2021 11:50 PM UTC
Hi @lopeztor​ Are you able to test your workspace using FME Desktop on Linux? Please send us your workspace and sample data via https://community.safe.com/s/submit-case/ Thanks!
  • Nov 12, 2021 1:37 AM UTC
Hi, I will set up an instance to test using FME Desktop on Linux and I will sent the case. Thanks for your response Dan.
