When trying to run a workspace I get an error saying "Undefined macro 'OUTFIELDS' dereferenced in file 'a file that doesn't exist'
  • Jan 13, 2023 7:17 PM UTC
  • 235 views
kpyke5
I created a workbench in an earlier version of FME workbench and then when I updated it to 2022.1 it eventually stopped working referencing an undefined macro 'OUTFIELDS' to a file that doesn't exist when the translation fails. I tried copy and pasting the workbench into a new workbench but that didn't work. I tried updating to 2022.2 but that also didn't work. I'm hoping someone here has had a similar issue and knows how to fix it. I am trying to avoid recreating the workbench from scratch because it is rather large
dustin
Forum|alt.badge.img+36
  • Jan 13, 2023 7:25 PM UTC
"OUTFIELDS" is likely a parameter causing the issue. What kind of parameter is that, and is the value populated correctly?
kpyke5
  • Jan 25, 2023 2:11 PM UTC
I'm not sure but I found where the error was coming from (a geocoder) by systematically deleting transformers and running the workbench until it worked.
