When I try to upload the workspace to FME server I get a error message saying "@Value(connection) is either missing or unsupported by this version of FME Server."
  • Feb 10, 2023 10:06 AM UTC
  • 69 views
hermann
Forum|alt.badge.img+11
In a FME workspace I have a SQLExecutor-transformer, which uses different database connections. I use one PostGIS-database per year called db2020, db2021, db2022, db2023.
When the user needs data e.g. for 2021 a sting is generated, which contains the name of the database, in this case "db2021". This string is called "connection" and is referenced with @Value(connection) in the connection field of the SQLExecutor-transformer. This works locally in FME desktop.
Alle connections are present both on FME desktop and on FME server.
Any suggestions or workarounds would be appreciated.
Best answer by ebygomm
If you mean this message, I just untick the box and upload the workspace
Forum|alt.badge.img+54
  • Feb 10, 2023 10:39 AM UTC
hermann
  • Feb 14, 2023 1:14 PM UTC
Problem solved. Thanks.
