What would be the fastest way to work out deltas between a feature service in portal and and the original dataset. We are talking about a table with over 700K records in it.
  • Sep 3, 2020 1:32 AM UTC
  • 53 views
oscard
Forum|alt.badge.img+23
  • Sep 3, 2020 10:22 AM UTC
Sorry my ignorance, but by deltas do you mean changes? If that is the case, you could try the ChangeDetector transformer: http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/changedetector.htm
  • Sep 3, 2020 10:40 AM UTC
The change detector is all good, but I'm trying to find a way of reading a lot of records really fast. Especially when I'm dealing with hosted feature services. Cause there's no direct connect to the esri data store by design..
