What can cause FMEWorkbench.exe to keep running, after I close the application?
The application itself is closed. And when I restart the application, a new fmeworkbench.exe process is started.
This happens when I haven't done anything in the application yet. Didn't run a workspace or created one.
I also tested it with the simplest workspace I could think of: a Creator with an Inspector. In that case the process fmedatainspector.exe is started. That process also never closes.
I use FME Desktop version 2021.1 as part of ArcGIS Pro on a Windows 2016 VMWare machine.
Does anyone have an idea what might cause this behavior?
Forum|alt.badge.img+50
That doesn't sound right. My first suggestion would be to reinstall FME.
nampreetatsafe
Forum|alt.badge.img+13
@Laurens Kusse​, I'm sorry you're experiencing this. There have been some reports of an issue similar to yours that our team is currently investigating. We, however, need some more information to confirm that we're looking at the same issue. You should've received an email about a Support Case that we opened up for you (C667979). Could you please run the system information report described in this article and send it to us by replying to the case email? Thanks!
