We recently upgraded our FME server and now the file upload in Server apps is no longer working? When i click upload file the app says "There was an error uploading the file."
mark_zl
richardatsafe
Forum|alt.badge.img+10
Hi @mark_zl​ ,
It would be worth confirming that the FME Core, FME Web Application and FME Engines are all running under the same service account. Beyond that, it could be a problem with file permissions, incomplete installations, or port changes due to HTTPS configuration. Typically your C:\\ProgramData\\Safe Software\\FME Server\\resources\\logs\\service\\current\\dataupload.log will have details on this issue. Feel free to create a case though and please include details of the operating system, architecture, configuration, upgrade methods, and logs files.
  • June 15, 2023
Hi@@mark_zl​ ,
Wa have the same problem. How did you correct this issue ?
