We Can't Get Raster in AutoCAD Read
  • Oct 26, 2021 3:24 PM UTC
  • 92 views
Good Morning:
We are trying to transform autocade dwg files to GeoTIFF. The log indicates that the 17,000 features are read except for the raster feature. Thus it fails when we try to write during the conversion.
I've attached the read log and the failure to read the raster
itsmatt
Forum|alt.badge.img+48
  • Oct 26, 2021 5:59 PM UTC
The FME doc says that rasters are supported so it shoooouuuld work.
perhaps fme is having a problem with the raster itself. As a test are you able to read the referenced tif file in the log with the Tiff/Geotiff reader? It could be that for some reason fme is having problems with the tif files
Perhaps you are correct because we are not even getting a tiff created as a result of the non-production of the raster.
kailinatsafe
Forum|alt.badge.img+24
Hello @blabrams_nara​ , have you tried out any Vector to Raster tutorials on the Community? In this article, 2D vector geometry is converted it to a single raster. Might be worth taking a look for ideas/hints on whats going wrong.
