UTF-8 Problem when using XSLT-Processor
  • Sep 21, 2020 10:48 AM UTC
  • 133 views
mattenp
I think, there's a bug in FME 2020.1. It's not possible to get an UTF-8 encoded result if I use the XSLTProcessor with UTF-8 encoded xml-doc as attribute and UTF-8 encoded embedded xslt-stylesheet attribute.
The XSLT-definition has also "<xsl:output method="xml" encoding="UTF-8" indent="yes" version="2.0" />" included.
Best regards,
Matthias
chrisatsafe
Hi @mattenp​ ,
Are you using Windows 10? If so, can you try enabling the Unicode UTF-8 Worldwide Support? to see if that resolves the issue you are experiencing?
Settings > Time & Language > Language > Administrative Language Settings > Change System Locale > Enable Unicode UTF-8 Beta:
mattenp
  • Oct 9, 2020 8:51 AM UTC
Hi @mattenp​ ,
Hi @chrisatsafe​ ,
yes, we are using Win10, but we can't set such option and this seems to be an beta-option.
Best regards,
Matthias
