Use a variable with INLINE QUERY
  • Jan 6, 2023 7:42 PM UTC
  • 6 replies
  • 377 views
Hello, I need to use a variable in INLINE QUERIER
This is valid SQL but I can't get it to run in FME. The print is just for testing. I would ultimately use the variable as a concatenation string.
DECLARE @ccount as varchar(20)
set @ccount = (select top 1(CYCLE) from CYCLE)
print @ccount
dustin
Forum|alt.badge.img+36
  • Jan 6, 2023 8:42 PM UTC
Is there a reason you are wanting to use InlineQuerier for this, instead of perhaps the Sampler to return the 1st record?
  • Jan 9, 2023 8:31 AM UTC
I suspect you need to use a SELECT statement to return the value of the variable.
Yes, I need to use the value in the variable as a prefix for another column
select Asset_ID, @ccount + '-' + formation from TABLE
just a simple multi line SQL statement .
Forum|alt.badge.img+54
  • Jan 9, 2023 2:23 PM UTC
The InlineQuerier is based on SQLLite so any SQL needs to be compatible, I don't know anything about variables but select top1 i don't think is valid SQL for SQLLite for a start.
Perhaps if you could explain a bit more about what you are trying to do there may be alternatives?
I need a single attribute value.. '_2003_date' appended to an attribute in a SQL table. I think the issue is a multiline statement in Inline query.
So if I can pass an attribute or scalar value to inline query. I can then use it to concatenate to other columns.
for example. this statement in my query works.
select Asset_ID, SPUD_DATE, 'test_append' + Type_Curve from AllASSETS.
I need the value 'test_append' to be read in and not hard coded.
@fizquierdo1973​ Test you SQL in DB Browser for SQLite. As @ebygomm​ suggests, InlineQuerier is based on SQLite so the SQL must be SQLite compatible. SQLite Tutorial is also a great resource for understanding the nuances of SQLite's SQL.
I don't think SQLite supports declared variables
