Upgrade to FME 2025 getting errors accessing temporary files during translation
  • Jun 2, 2025 1:44 PM UTC
  • 7 replies
  • 418 views
mgrimnes
Forum|alt.badge.img+9
I have a workspace that works without issues in FME 2024.2.1. We are planning to upgrade to FME 2025, but I am facing issues. When riunning the workspace in FME 2025, it seems to work fine, but after a while I get lots of a recurring message like this one:
2025-06-02 11:38:25| 119.2|  0.2|ERROR |FFS reader: Failed to open file 'D:\FMETemp\wbrun_1748852462857_30000\fmetmp_0\FMETable_1748853274266_18156\FTShim_1019.fts' for reading.  Please ensure that the file exists and you have sufficient privileges to read it
These messages DO NOT appear when running the workspace in FME Form/Flow 2024.2.1
I have tried FME Form/Flow 2025.0.2 and FME Form 2025.1 (beta) and all of these fails.
I have set my FME_TMP environment variable to D:\FMETemp
Does anyone have an idea?
DanAtSafe
Forum|alt.badge.img+23
  • Jun 2, 2025 4:55 PM UTC
Hi ​@mgrimnes Do you get this error by stepping through transformers with feature caching enabled? Please submit a ticket here: https://support.safe.com/hc/en-us/p/Support
mgrimnes
  • Jun 3, 2025 8:09 AM UTC
Hi ​@deanatsafe I don’t know, I haven’t tested. I will go ahead and run my workspace in Form 2025.1 with Feature Caching enabled and see what happens - if my PC is able to store all feature caches though. I will create a ticket for this after this test.
itay
Forum|alt.badge.img+19
  • Dec 2, 2025 11:07 AM UTC
n
gtimms
Forum|alt.badge.img+25
  • Mar 3, 2026 9:10 AM UTC
Hi ​@mgrimnes, did you find a solution to this issue or did you end up creating a support ticket?
We have some users experiencing this so it would be good to know what you found out. One solution I found from a few years ago was copying the workspace into a new FME Form canvas, but that hasn’t been tested in our version of 2025 yet.
Thanks!
mgrimnes
  • Mar 4, 2026 8:53 AM UTC
No I didn’t find a solution for this. I got hooked up on another, more recent, project with the same customer.
The idea of copying the workspace to a new canvas is likely a good first step. The workspace was last saved in FME 2024.2.1 and a custom transformer was last saved in 2023.1.1.1. The customer is planning for an upgrade to FME 2025.2.3, so this might be a good time to upgrade the workspaces and custom transformers to the new version by copy/paste and see what happens.
alexandre
Forum|alt.badge.img+4
  • Aug 3, 2026 9:02 AM UTC
Do you have some news on the issue?
I recently started to see the issue occuring on a workspace.
crystalatsafe
Forum|alt.badge.img+32
Hi ​@alexandre
This issue should be fixed in 2025.2 (internal reference: FMEENGINE-89466).
You can download FME 2025.2 at: fme.safe.com/downloads/#v2025.2.4.1.
Please let me know if this fix solves the issue.
