Update multiple geodatabases
  • Nov 28, 2019 11:33 AM UTC
  • 49 views
franco69
Forum|alt.badge.img+11
Hi Guys...a simple one for you i think
i have a Folder A with multiple .gdb files and a Folder B with multiple .gdb files
No I want update every gdb which is in Folder A and in Folder B
AND: write gdbs which are only in Folder A into the Folder B
have i use a loop? (because the Folder A is Always filled with different Counts or names of gdbs)?
or dynamic path etc....??
thx for help
Franco
@franco69 You should be able to use a combination of the Directory and File Pathnames reader and the File Copy writer. One Directory and File Pathname reader for each of folder A & B to compare the lists of File Geodb names using something like ChangeDetector and then copy the unique ones from A to B using the File Copy writer.
