unable to create geometry from JSON
  • Apr 23, 2021 6:27 PM UTC
  • 176 views
amolparande
Hello FME Users,
I have JSON file in it having Polygon and "coordinates"  I could not able to create geometry from it I tried to use JSONFragmenter and Fragment as formate = GeoJSON but could not had luck. Can any one help me to create Geometry I am also attaching JSON file for reference
nampreetatsafe
Forum|alt.badge.img+14
Hi @amolparande​ ,
I took a stab at this and I think I managed to get a polygon feature using the JSON Reader.  There might be a better way to do this, but this seemed to work for me.  In the JSON Reader parameters, I used the following JSON Query for the Feature Type:
json["messagePayload"]["areas"]["00005831-3100-1200-0000-00007d3134f3"]
I then set the "Geometry Name Key" to geometry.
I've attached the workspace with the Reader.  Hope this helps!
amolparande
Hi @amolparande​ ,
@nampreetatsafe​ Thank you it's Working now
