Trouble connecting to MongoDB
  • May 30, 2023 5:22 PM UTC
  • 189 views
Attemping to connect to a hosted mongodb I get this error message:
MONGODB3 reader: Server at xxxx:yy reports wire version 5, but this version of libmongoc requires at least 6 (MongoDB 3.6): generic server error
I can see FME's reader doesn't like some app version on my db server. Is this something I can resolve in FME, or does the server require updating to allow FME to connect to it?
Thanks,
Clay
egge
Forum|alt.badge.img+14
  • May 31, 2023 8:33 AM UTC
You are using the MongoDB3 Reader, which is the way to go: "Notice: The MongoDB3 format replaces MONGODB. All new workspaces (FME 2019.1+) should use this format."
There is also an older, and now deprecated MongoDB Reader (Deprecated) for FME pre-2019.1.
I don't know too much about MongoDB but it looks like you should update your db (unless you can get hold of an old version of FME to play around with...)
  • May 31, 2023 4:45 PM UTC
Allright thanks. I was hoping readers were like plugins and I could just add an older version. I do not know if I can get my hands on an older FME, but I do know I have 0 control over the mongoDB.
