Top down georeferenced image from photomesh
  • Aug 30, 2021 7:54 PM UTC
  • 177 views
jdh
Forum|alt.badge.img+41
I have some photomesh files that I would like to turn into 2d top down raster images. Is there a way I can accomplish that in FME while preserving the georeferencing. Most of my viewing software allows me to export a snapshot, but the geocoordinates are not preserved.
Original data (obj)
photomesh-obliqueDesired output (geotiff)
photomesh-top
I can't just use the texture files because they are spaghetti.
m-00031
itsmatt
Forum|alt.badge.img+48
  • Aug 31, 2021 8:58 AM UTC
Ideally you should get the original orthophoto used to create the textures of the mesh. I can't think of an FME workflow that would let you do this. But it's an interesting problem for sure. I shall follow this thread with interest. 😏
jdh
  • Aug 31, 2021 1:34 PM UTC
Getting the original orthophoto would be ideal, but unfortunately not possible.
I tried converting the mesh to a pointcloud and then using the imageRasterizer and while that mostly worked, there were a few surprises, particularly in the tree at the lower right.
photomesh-FMETreeI might need to try and filter the pointcloud to only the highest z or something.
itsmatt
  • Sep 1, 2021 7:24 AM UTC
Ohhh of course, what an excellent idea. Yeah very strange in the corner there, strange that it's very much in a grid form. I've has some issues when converting point clouds to raster, I've found that snapping the points to a grid and then getting the max z for each new grid point works well - there were some tricks in a couple of point cloud articles that helped with this. The data I worked with though was not RGB but height values so didn't matter to much about how it looked.
jsmitsman
  • Nov 14, 2022 4:45 PM UTC
I had the same idea and the same problems.
I solved this problem by using the PointCloudSorter and sorting the Z component in ascending order. That resolved the problem in my case.
