Timezone offset does not match system offset.
armando_amador
Forum|alt.badge.img+4
When using Sharepoint Online Connector, this error message appears "timezone offset does not match system offset: -18000 != -216000. Please, check your config files."
I'm from Mexico timezone, how can this be solved?
armando_amador
@danilo_fme​  do you have a suggestion about this?
bradr
Forum|alt.badge.img+8
  • December 31, 2024
In 2024.1 I got an working Web Connection with the ‘Microsoft SharePoint Online (safe.microsoft-sharepoint)’. In the SharePointOnlineConnector when choosing ‘Site’ I got this popup
But no Translation log.
If I use ‘User Parameters’ to fill in Site and  Document Library it is possible to run the workspace
The ‘timezone’ error is shown in de log:
Message Type: fme::internal::_v0::py::Exception
Python Exception <ValueError>: Timezone offset does not match system offset: 0 != 3600. Please, check your config files.
Error encountered while calling method `input'
SharePointOnlineConnector_CALLER (PythonFactory): PythonFactory failed to process feature
Questions
  1. what does the ‘timezone’ error means
  2. where is the config file located
bradr
  • February 5, 2025
In Windows 10 it works if the timezone is set to (UTC)  in stead of ((UTC+1:00) etc.
But then my Windows clock is offset.
Can it be configured in FME in stead of Windows.
