Testing an integer length?
  • Jan 9, 2024 4:55 PM UTC
  • 131 views
smithgk
Forum|alt.badge.img+10
Hello, is there a way to test an integer's length within the TestFilter transformer? I have an integer column that can be freely populated with values, but I need to flag rows that are not 6 characters long. Is there some operation in the Test Clauses window that I can use to test for this?
Best answer by david_r
You can use the @StringLength() function, for example if your integer column is called "num":
  • Jan 9, 2024 5:15 PM UTC
dustin
Forum|alt.badge.img+36
  • Jan 9, 2024 5:16 PM UTC
You can use the following in the TestFilter.
@StringLength(@Value(att)) < 6
smithgk
  • Jan 9, 2024 5:36 PM UTC
Oh that is it! Thanks so much David. I had found the @StringLength function but wasn't nesting it with the @Value function. Right before you posted this, I was testing using the StringLengthCalculator to create temporary attributes and test them. This solution simplifies things a lot for me, thanks again!
