SystemCaller fails to run simple Windows command on FME Server
  • May 26, 2021 11:51 AM UTC
  • 330 views
pmcpherson
Forum|alt.badge.img+11
I'm trying to use FME Server to execute a Windows command but the SystemCaller returns code 1 with no details. The same workflow works fine on FME Desktop. I've read a few articles here in the formum regarding the correct use of UNC paths and folder permissions, but none seem to apply in my case. Have others had success using the SystemCaller transformer within Server to execute commands or batch files on the machine running Server?
nielsgerrits
Forum|alt.badge.img+67
Yes I had succes with a SystemCaller on server (2019.2.1).
First thing I would try is something simple like
ping 127.0.0.1
if this returns ExitCodeAttribute = 0 it works. Then try to write the result to a textfile to see if you have the correct permissions.
pmcpherson
  • May 26, 2021 7:11 PM UTC
ping 127.0.0.1
Believe this is working okay, and that I was basically confusing myself. The SystemCaller was needed to execute a plink command and redirect the output to a local (temporary) file. The thing that was most confusing was that the log output from Server was different than Workbench, and that led me to believe the command was not running when it actually was running. Thanks for the feedback!
