start workspace by http-Request -> Send response
  • Aug 18, 2023 1:15 PM UTC
  • 99 views
Hi everybody, I created a Workspace. This Workspace should be started by an external http-request. If the workspace ended, i wanted to send back a response. I published the Workspace with fmedatastreaming + included the writer to the stream.
imageThe response was send as a file. I wanted to send the response as content in response.
Any Ideas?
  • Aug 18, 2023 1:25 PM UTC
Which writer are you using and what is the output filename defined on the writer in your workspace?
Also, try tacking "opt_responseformat=json" to the end of the URL.
  • Aug 18, 2023 5:28 PM UTC
I tried Json- weiter, Textfile weiter, html-writer. The Filename ist Protokoll-1645.txt or I tried response.txt
  • Aug 22, 2023 8:24 AM UTC
I've solved my problem. Now I use a textfile Writer. It's content is a json value. I dont't need the parameter opt_responseformat=json
