SQLExcutor results now a row not columns
  • Aug 27, 2020 7:14 AM UTC
  • 8 replies
  • 80 views
rudy_v
I have upgraded my sqlexcutor transformer - now the result ashow as single, row , delimited and shows missing.
is this the way it should work - or a bug?
before (version 8)
Capture
after upgrade (version 9)
Capture2
Best answer by hollyatsafe
Hi @rudy_v​ ,
I'm sorry that you have encountered this issue. I was able to reproduce it so I have filed a ticket (FMEDESKTOP-10650) to request this fix.
In the meantime I'd recommend either stick to working with Version 8 for now, or alternatively with Version 9 rather than exposing attributes within the SQLExecutor you can use the AttributeExposer after the 'Result' output.
In this particular workflow, since you are using Creator > SQLExecutor, swapping this out with the SQLCreator might be a third option. I have confirmed this does not have the same issue.
UPDATE: This issue has been fixed for FME 2020.1.2.
Forum|alt.badge.img+54
  • Aug 27, 2020 7:23 AM UTC
What happens if you go into the SQLExecutor and go to Attributes to Expose and choose Populate from SQL Query?
rudy_v
  • Aug 27, 2020 7:54 AM UTC
@ebygomm​
it shows 6 columns, but when you click ok, it changes to one row of attributes, separated by comma.
It works perfect - if you leave it at version(8) of sqlexcutor, but as soon as you upgrade it or use a new one , it makes all the columns, as 1 row of columns, with comma seprated, and shows values as missing
  • Aug 27, 2020 8:14 AM UTC
That's weird, I've never seen that before.
Can you show us the SQL, or at the very least the SELECT part?
itsmatt
Forum|alt.badge.img+48
  • Aug 27, 2020 9:39 AM UTC
Yuck, that's not fun at all. Maybe it's better to delete the transformer and re add a fresh one. Sounds nasty
  • Aug 27, 2020 9:08 PM UTC
Hi @rudy_v​ ,
rudy_v
  • Aug 28, 2020 12:06 AM UTC
Hi @rudy_v​ ,
@hollyatsafe​
Thanks - i thought it was an issue, but you cannot use it with new work benches, as it only has version 9, but i have used FME 2019, created it with version 8, and then open with 2020 to continue
My example is just one of many we have - probably over a 100+
So i have send to all developers to not upgrade the sqlexcutor to version 9
Regards
Rudy
  • Aug 28, 2020 7:20 AM UTC
@hollyatsafe​
Regards
Rudy
Another possibility is to simply copy/paste the transformer between FME versions.
rudy_v
  • Sep 12, 2020 11:04 PM UTC
Good Day,
Thanks - SQLExecutor are working correctly now with the updated release of 2020.1.2
Rudy
