Splitting line between vertexes - or I get bald
  • Jun 3, 2022 10:07 AM UTC
  • 388 views
Hi Experts,
I'm tearing my hair out ... 🙂
I have a line (with approx 500 vertexes), the length between each of them is never the same....
My goal is to split the distance between each vertex into 5 equal lenghts.... in other world I would like to resample my line with approx 500 vertexes into 2500...
I'll do everything for help...
Maaasive thank you
Forum|alt.badge.img+63
I'd say:
  1. Chopper, set to 2 max vertices so your line is split up in 500 segments
  2. Lengthcalculator to calculate the lengt of each segment
  3. Densifier with exact interval set to length/5 to add 5 equally spaced vertices
  • Jun 3, 2022 10:36 AM UTC
I'd say:
Thanks,
May I ask - will chopper change the existing vertexes?The vertexes I already have (approx 500), their lat/long can't be changed.
j
Thanks,
j
No, the Chopper will not change those vertices (neither will the Densifier for that matter)
Hope you've kept your hair 😉
  • Jun 3, 2022 10:52 AM UTC
Thanks,
j
Thanks to you :)
Let me work on this and will get back to you..
j
